Hey there I’m working on a ps4 1215 I got cheap and wasn’t working. The situation I’m describing is my avatar Pic.
After opening it I found two little capacitors near the big tall power supply connector.
What are the specs on these? I think 25uf but voltage? Are they both identical?
Which pads are positive and negative?
3.i accidentally bridged two pads. Does it matter? Do they have continuity anyways? I can clean this up desoldering braid I’m just waiting for some to come in.
- If the pads are bad where could I solder wires to instead?
Thanks for reading this whole thing.
