I’m kinda new to this forum, but when I was little I always played with electronics. Now my question is I have a Nintendo switch with black screen I removed the max77620 and the m92 but still I get shorts on the caps next to the max77620 does any one know where these caps go to?
I marked the shorted caps with red circles
If someone has any ideas or tips pleas contact me or post in this topic
Would guess the caps your talking about aren’t actually shorted to ground, instead of measuring continuity put your meter in resistance mode and lemme know the resisance to ground on the caps in question.
Black screen and no boot logos could be battery connector joint issues, fuel gauge issues, EMMC issues, BQ issues (rare) and a couple of other things, can you take some hi res photos of all those things so I can take a look and in regards to the EMMC a photo front and back of the modules PCB
This is normal on Mariko, not your issue, the IC’s you’ve removed are not at fault, you’ll have to reball with stencils and solder paste and reinstall before going forward
The lines are the burned pins and the circle is the side of the cap that was burned I re tinned the pins and put back all ic’s and am back where I started with the same reaction in dock that the light goes on/off
