Blown 7002 fuse and diode search close to encoder
Hi guys!
I have a blown 7002 fuse in a EDM-040 board. I have another 041 board that I borrowed from a friend and this fuse looks slightly “different” than the one in the 040 board by color and maybe by symbol, I’ll elaborate, the 040 has like a darker tone color tan the 041, and sincerely I can’t see if this is a minus symbol or nothing on it, could anyone please check it out and tell me which fuse do I need? See image down below
ht tps:/ /ibb. co/ 0RCy492T
ht tps:/ /ibb. co/ hR2P9hcz
Also, I have a diode with no reading in one side where is supposed to be a reading, this diode is closer to the HDMI encoder IC. See image down below
ht tps:/ /ibb. co/ nvrgRXB
Now the story behind all this trouble. This unit 040 came with a beep on beep off and no lights turning on. Also, there was a torn pin inside the hdmi port, so I decided to change it as part of the fixing, however, it didn’t solve the main issue. I changed the southbridge (because I tried to connect it to uart but nothing came up) and tried to use as less flux as I could, I was happy with the results and the readings, but still, I had the same beep on/off no lights problem. So I decided to change the HDMI encoder for a new one and after that same problem arose. I tried to inject 3v and 1 Amp to the 3.3v rail of the PMIC RT5126 and this IC was the only one that was hot enough to detect it in the thermal camera in fact it was the only visible thing highlighted on the board, then I changed it by a new one but still I had crazy booting sequences like steady 0.020 and then 0, later on I tried to reflow the IC in case it was a bad installation but it got worse to steady 0.004 and then 0, again, I tried to lifted it up and then passed around one more time the solder iron on the chip, after I installed it, cleaned the board, I injected the 12v 1 Amps to see the boot sequence and surprisingly I had a steady 0.132 and then I could hear like a electric “pop” (it wasn’t that louder to worried me at that moment but enough to made me think that something was wrong), after that “pop” the 0.132 Amps went down to 0, and now, every time that I try to inject the same 12V 1 Amps with my power bench, it starts in 0 and ends up in 0.001-0 Amps, in the meantime I will see if I can get the uart but seems likely that I will not be able to get data because my intuition says that the SB is not even starting at this booting sequence, correct me if I’m wrong though.
Now my theory is that it could be possible that some of the pins of the PMIC that I was installing, there were bridged and the stand by voltages could fried the 7002 fuse with either 3.3V, 5V or combination of both, but I remember that before installing the new RT5126 I checked the fuses in diode mode and they were good, beeping all in both sides, now I checked all of them again and the only one that is not beeping is the 7002 one, what I could read in diode mode in that fuse is in the image below.
ht tps:/ /ibb. co/ B2tJnVt6
I checked in diode mode that fuse in the 041 board and I have the following readings. See the image down below.
ht tps:/ /ibb. co/ cS0ng0vs
I don’t know if the 040 and 041 share the same traces, definitely not the same fuse 7001 as far as I can see, but I can’t verify this without schematics…
In any case, I must add that I was “tracing” the 7002 fuse in the 041 board in continuity mode and I could see that there’s a relationship between this fuse and (obviously) the 7001, 7003 and 7004 fuses but also the ssd power controller regulator, flipping up to the other side of the board (Where the southbridge stands), my thought is that this diolog IC (I guess is known to other boards as RT5127) might be good? Because the fuse could “protect” it blowing itself up?
ht tps:/ /ibb. co/ XQrfTzs
So, I need to gather more info about it, I saw a “How to repair PlayStation 5” guide (You can look it up in SCRIBD, very useful and I’m grateful for the people who put it together) in page 42 says:
“When you see a current draw in standby of
175 mA and then back to 10Ma. There can be
a bad SSD controller IC.
Remove fuse F7520 that feeds the voltage
on the back to the voltage regulator that
generates power for the SSD circuit.
Set a multimeter in current mode in series
with the pads of the fuse and measure the
current draw.
Good working SSD circuit draws: 310mA.
If current is different on a faulty board
change the SSD controller IC.”
Of course, I can see that this guide was created based on the EDM-010 board and I could see that they described the fuse 7502 and in my case, I can’t find this fuse in the 040 board… so I don’t know if I should try this with the blown F7002, what do you guys think?
And yes, before I went crazy replacing the southbridge I dumped the bios nor with the ch341A programmer and the nor was good for reading, I saved the dump as a bin file, erase the chip and write it again to se if the chip was good and yes was good enough to even verify it. Unfortunately at that point I didn’t know about the trick of seeing the errors from 0x1C5100 that would’ve been so much useful (thanks @calvin !! :D). And yes, I checked the caps behind the WiFi module IC and there were no shorts. And finally, I ended up changing the HDMI encoder IC by a new one because the caps readings around the encoder weren’t 240 as many guides or posts that I have seen in the forum and I wanted to make sure that if the HDMI port was compromised then I wanted to change both to be sure that the problem wasn’t any of them.
Thank you so much for reading this and any help would be really much appreciated :smiley:
Hi @Calvin thanks man, really appreciate it. I think I watched your repairing videos in YouTube one time hehe
Just a few questions, I can see that in this table you don’t have any mark of the symbols, is that irrelevant to buy the fuse once you have the voltage and the Amp code? Another question, I found this one in AliExpress, would you recommend it? In case you don’t, what do you suggest to look at before buy the 7002 fuse?
ht tps:/ /a. alie xpress. com/ _Ewtwzsm
Lastly, do you know the diode specs in this photo:
I got a Switch Oled for parts repair, is there a chance to take it from it or even the diode?
The marking on the fuse is irrelevant if you know the needed amps.
Before the schematics were out I tried to find the amp readings of the fuses by the markings at the usual manufacturer for fuses.
Here is a link to fuses from Aliexpress: https://de.aliexpress.com/item/4000222232143.html
The four diodes to ground around the HDMI chip are ROHM CDZVT2R5.6B
The USB C input fuse at a Nintendo Switch is only 3A. The diodes Idk.
God bless you man. Thanks for helping me and many others.
I’ll buy the fuse as you suggested and report back when I installed it.
would you recommend any vendor in AliExpress to buy that Diode? I copied and pasted the model as you posted it but I couldn’t find anything in AliExpress. Thanks again!! :smiley:
Hi again,
I just want to give you all an update, I replaced the fuse and lucky for me the diode CDZVT2R5.6B that @Calvin mentioned before was fixed, y reflow the encoder and passed again the iron and now the pins looked so much better and with readings, that problem is fixed.
Now, with the fuse 7002 replaced I could run the UART and I come here to ask for help or some guidance, I gonna look up the old threads as well to see if I could fix this but I still have the one beep no lights problem but with some error codes at least
Andyman UART
errlog 0:DB
errlog 0:DB
OK 00000000 8089403A FFFFFFFF FFFF00F6 10000000 217B 0000 FFFF FFFF:5C
errlog 1:DC
errlog 1:DC
OK 00000000 80892003 FFFFFFFF FFFF00F6 10000000 217B 0000 FFFF FFFF:49
errlog 2:DD
errlog 2:DD
OK 00000000 80891001 FFFFFFFF FFFF00F6 10000000 217B 0000 FFFF FFFF:46
errlog 3:DE
errlog 3:DE
errlog 4:DF
errlog 4:DF
errlog 5:E0
errlog 5:E0
errlog 6:E1
errlog 6:E1
errlog 7:E2
errlog 7:E2
errlog 8:E3
errlog 8:E3
errlog 9:E4
errlog 9:E4
errlog 10:0C
errlog 10:0C
errlog 11:0D
errlog 11:0D
errlog 12:0E
errlog 12:0E
errolog 13:7E
errolog 13:7E
NG F0000006:51
errlog 14:10
errlog 14:10
errlog 15:11
errlog 15:11
UARTCODES by Th3Cod3r
12:14:17 UART Connection Established.
12:14:24 Starting automated error dump…
12:14:24 errlog 0:DB
12:14:24 OK 00000000 8089403A FFFFFFFF FFFF00F6 10000000 217B 0000 FFFF FFFF:5C
12:14:25 errlog 1:DC
12:14:25 OK 00000000 80892003 FFFFFFFF FFFF00F6 10000000 217B 0000 FFFF FFFF:49
12:14:25 errlog 2:DD
12:14:25 OK 00000000 80891001 FFFFFFFF FFFF00F6 10000000 217B 0000 FFFF FFFF:46
12:14:25 errlog 3:DE
12:14:25 OK 00000000 8089403A FFFFFFFF FFFF00F6 10000000 217B 0000 FFFF FFFF:5C
12:14:25 errlog 4:DF
12:14:25 errlog 5:E0
12:14:26 errlog 6:E1
12:14:26 OK 00000000 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFF FFFF FFFF FFFF:5A [Empty Slot]
12:14:26 errlog 7:E2
12:14:26 errlog 8:E3
12:14:26 errlog 9:E4
12:14:26 errlog 10:0C
12:14:27 Error dump complete.
Console Service Tool
[*] Operation: Run Read Error Codes
[Slot #] [Date Time] [Error Code] [Priority] [Error Message]
00 06/09/2026 12:12:20 8089403A High Not found in list. Report Findings.
Click Here To Report
|-(OK 00000000 8089403A FFFFFFFF FFFF00F6 10000000 217B 0000 FFFF FFFF:5C)
Click for TSB Information
01 06/09/2026 12:12:20 80892003 Low SSD Controller or DDR4 Error (Power Failure or Short Circuit)
|-(OK 00000000 80892003 FFFFFFFF FFFF00F6 10000000 217B 0000 FFFF FFFF:49)
02 06/09/2026 12:12:20 80891001 Low SSD Controller or DDR4 Error (Power Failure or Short Circuit)
|-(OK 00000000 80891001 FFFFFFFF FFFF00F6 10000000 217B 0000 FFFF FFFF:46)
03 06/09/2026 12:12:20 8089403A High Not found in list. Report Findings.
04 06/09/2026 12:12:20 80892003 Low SSD Controller or DDR4 Error (Power Failure or Short Circuit)
05 06/09/2026 12:12:20 80891001 Low SSD Controller or DDR4 Error (Power Failure or Short Circuit)
06 06/09/2026 12:12:20 FFFFFFFF Low No Errors
|-(OK 00000000 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFF FFFF FFFF FFFF:5A)
End of errors.
Low: Nothing to concern about first.
Medium: Everything appears fine.
High: Console may boot but freeze or other issues.
Severe: Prevents console from booting.
I’ve seen some people replacing the SSD Controller with no success, so I’m worried that this issue could escalate to something more difficult, but I guess it is what it is at this point. Would you all recommend before doing something to the SSD Controller check if the RT5127 could be the issue or the RT5126 and I’m sorry to be ignorant at the moment.
Thanks in advance as always and I would really appreciate some help.
I would check the readings around the DA9081/RT5127.
The output voltages OUT1-OUT4 should show up for some seconds after start-button-press.
