Hello, my brother stepped on the power supply and broke the connector. The broken connector is 300cr, luckily we have power from the old pro console, but its different type of connector, its 300fr. The question is can the power supply be replaced so that nothing burns?
You really only have to make sure that the small connector with 4 or 5 pins matches the one you have on your motherboard. everything else is basically the same.
If the connectors does not match, you can take a soldering iron and make a 4to5 pin adapter since the voltages on that thing are the same. For info about pinning you can search online
