EDM 033 2160p black screen
Hi my friends @Calvin @jkyoho , I need some advice.
The original fault was already present before replacing the HDMI port.
The console had:
- black screen / intermittent image
- artifacts/sparkles
- image cutting in and out
I replaced the HDMI port as a possible cause, and then replaced it a second time to completely rule out a bad port, but the exact same issue remains.
Current symptoms:
- Safe Mode: perfect and completely stable
- 1080p: perfect
- 1440p: perfect
- 2160p: artifacts/sparkles appear and the image starts cutting in and out / flashing to black
- Moving the HDMI cable does not affect the image
- Tested on another TV with the same result
- All HDMI pin diode-mode readings look correct
- A6 and A71 diodes have already been replaced
So the fault clearly seems to appear only at higher HDMI bandwidth.
Has anyone had this exact issue and actually fixed it?
Thank’s
run QA inspection check memory and cpu first?
UPDATE:
I did some more testing:
- 2160p with “4K Video Transfer Rate” set to -1: still flashing
- 2160p with “4K Video Transfer Rate” set to -2: completely perfect and stable
I also took screenshots while the TV was showing a black screen, and the screenshots are perfectly clean with no artifacts.
It really seems bandwidth-related. Could this point to the HDMI encoder or filters/chokes?
I’ll try QA this afternoon
It seemed to be solved by replacing the encoder but nothing…Even with donor encoder same problem
QA inspection All tests with positive results
