Hello,
I have a console (EDM-010) where the power (on/off) button does not work, though the eject/disc drive button does. The console boots up when a CD is inserted and functions normally. All USB ports are working, I have confirmed 3.3V at the connector, and there are no issues with the button itself or the ribbon cable. The UART output shows two errors: 808C4E90 and 808C3790.
Does anyone have any ideas?
POWER BUTTON Goes from the button to flex and into 120 ohm resistor next to small cable connector, then through 4.7k ohm resistor before going into Southbridge, check the resistor value
Calvin
I took measurements on my board, and none of them match. This is complete nonsense! I have no idea what to do now.
Jkyoho
I had already checked those values, and they are correct.
I connected a bench power supply, and when I press the button, the power draw doesn’t go above 11mA. The worst part is that once it’s booted up, it works perfectly.
What are your measurements for USB c controller and muxer?
