got my hands on a Switch with an broken lcd connector and Manager to replace that. Replacement Was quiet a success, but i noticed that the Fan is running all the time at full throttle.
Fan stops running for a second when the Powersupplie is attached. Somebody has some advise for me?
Try removing and cleaning off all the old thermal compound and put some new compound on. Its more than likely that because you opened it and changed the screen the old compound is no longer up to scratch.
I use Arctic MX4 usually, really great for consoles.
Hi, i had a similiar Problem. After replacing the connector, the switch fan would run full throttle when the switch powered down. This problem was caused by a bad connection between fan connector pins and mainboard pads.
