Hi All, my son accidently dropped his Switch in the toilet (Dont ask me how and there was no contaminents in that toilet at the time, thank god).
I took the switch apart looking for water damage, cleaned it up etc and the game cart was quite corroded inside and on the outside which i suspected was an issue. Instead of attempting to clean it i changed it.
However after this now i am getting the ghost touch issue, before it was intermittant but then started behaving, now its just all the time.
I did read that there is a V1 V2 compatibility issue and that it is possible that if its a v2 switch and i put a v1 board in it could cause this issue. How can i tell the difference between the game cart boards for V1 or V2.
I believe the switch is a V2 as it has the QR code on the ribbon cable connecting to the board.
Is there any thing to look out for so i can check the one i have as a replacement and if its wrong i can then order the right one.
Cheers in advance.
