Hi guys, I’ve accidentally removed 2 tiny cap on the right to the Emmc. Can someone help me identify the caps so I can replace them? I have find nothing on the forum.
pasteboard co/0v4sZfKsQoU1.jpg
I’ve find out they are probably resistors
Both are 4.7 kOhm resistors.
Thank you very much, do you know the value of the bigger resistor a little higher?
It is a diode.
But your board seems to be another revision than HAC-CPU-10, -20 or -21. On those boards there is no diode in this spot.
Mine is a v2(2019) HAD-CPU-01, and I’ve the diode. Thanks once again for the help.
