This is for the HAC-001(-01), Recently picked up a water damaged switch one of the caps flew off into the void while cleaning and i am looking to double check the values, right now i am having a hard time looking for a reference for the cap.
Right now the issue that its causing from what i can tell is that the Fans run 100% when powered off.
I checked an alternate board with the cap and i got the following.(used a cheap checker)
68.32uf
vloss=9.3
esr=95 ohm
No clue on what the size is other than its small as heck.
Link to image here [Preformatted text](https://pasteboard.co/Rh9TxFgI6vtD.jpg)
