Nintendo Switch HAC-CPU-20 — No Boot, 15V USB-C, 0–0.03A Draw, Missing CPU/GPU Rails
Hi everyone,
I’m troubleshooting a Nintendo Switch motherboard (HAC-CPU-20) that refuses to power on, even with a charged battery.
I’ve performed quite a few measurements but haven’t been able to identify the faulty component or determine why the startup sequence isn’t completing. I’d appreciate some guidance from experienced board-level repair technicians.
1. Original problem and repairs
  • The Switch does not power on or display anything.
  • Initially, the USB-C charger would only negotiate 5V.
  • I discovered that the fuse above the USB-C port was blown and replaced it.
  • After replacing the fuse, the Switch successfully negotiates approximately 15–15.28V.
  • I’ve also replaced the USB-C connector twice.
  • The console still doesn’t boot, even with a charged battery (approximately 3.8V).
2. USB-C power consumption
With a USB-C power meter connected:
  • Voltage remains stable at approximately 15V.
  • Current fluctuates between 0.023A, 0.027A and 0.030A.
  • Eventually, current drops to 0.000A.
  • Voltage remains at 15V even when current drops to zero.
I’m unsure whether this indicates a startup-sequencing issue, a protection condition, or something else.
3. BQ24193 charging IC
Measurements with 15V USB-C power:
Signal Reading
VBUS 15V
PMID 15V
REGN 6V
CE 0V
SYS (battery connected) ~3.7–3.8V
SYS (battery disconnected) 0V
SW (battery connected) ~3.7V
TS (battery connected) 0V
TS resistance to GND 5.6kΩ
I initially suspected the BQ24193, but I haven’t found enough evidence to confirm that it’s defective.
4. M92T36
  • USB-C successfully negotiates 15V.
  • Test point B-5 measures 3.3V with the charger connected.
  • XRST previously measured approximately 3.02V.
I haven’t confirmed that the M92T36 is fully functional, but input negotiation appears to work.
5. Switchbrew test-pad measurements
With a charged battery connected and USB-C disconnected:
Test point Voltage
G-5 — Battery supply 3.8V
B-5 — 3.3V 0V
C-11 — 1.8V 0V
D-3 — 1.15V 0V
E-2 — 1.1V 0V
D-2 — CPU 0.8V 0V
G-3 — GPU 0.8V 0V
With the battery and USB-C charger connected, B-5, C-11 and E-2 have their expected voltages, while D-2, D-3 and G-3 remain at 0V.
Test point E-10 stays at approximately 1.8V before and during a power-button press.
6. Resistance measurements compared with donor boards
All measurements taken with power disconnected.
Rail Faulty motherboard Donor motherboard
D-2 — CPU 0.8V 330Ω 70Ω
D-3 — 1.15V 32Ω 23Ω
G-3 — GPU 0.8V 72Ω 20Ω
The faulty motherboard has higher resistance on all three rails, so I haven’t found an obvious hard short there.
I also checked V3 near the MAX77620. It measures approximately 52Ω to GND, similar to my donor boards.
7. MAX77620 observations
Using a repair guide, I measured several regulator outputs.
Some rails were present, including approximately 1.8V, 1.34V, 1.1V, 3.3V and 0.8V at different measurement locations, while several others remained at 0V.
These measurements were not all taken under identical power conditions, so I haven’t established the complete startup sequence.
8. Equipment available
  • Multimeter
  • USB-C power meter
  • USB-C breakout board
  • Microscope
  • Soldering/rework equipment
  • Donor Switch motherboards (without M92T36)
  • No bench power supply or oscilloscope
Questions
  1. Given that 15V negotiation works and the Switch has a charged battery, what would you investigate next?
  2. Could the missing CPU/GPU rails indicate that the MAX77620 isn’t receiving the correct startup commands?
  3. Which test points or control signals would help determine why the power-up sequence stops?
  4. Is there a known HAC-CPU-20 fault that produces this particular low-current, no-boot behavior?
  5. Are there any reliable boardviews or schematics that could help trace the missing power rails?
I’m trying to identify the actual cause before replacing any more ICs.
Thanks in advance for any advice!
