Nintendo Switch Lite USB-C Port
Anyone know where to purchase these ports for the Lite? The sizes are completely different compared ot the original Switch.
It’s not that different. It is a little longer by 2-3 mm. I put it on Switch Lite and it works perfectly. It comes out a little but not very visible or annoying.
We have been using the original NSW USB-C port for the Lites, however, you should open up the hole in the case to relieve the tension on the port.
You can watch Steves video on replacing the lite usb-c port, he uses a normal switch port, and files it a bit to make room. “I Paid $150 for a BROKEN Nintendo Switch Lite - Let’s Fix It!” on Youtube.
Just buy normal switch ports and chop a little bit off the end
