I received a Nintendo Switch with a BSOD. I have done a SoC reflowing which seems to fix the issue and Switch is booting up again.
With the final tests I have seen that the dock mode is not working and there is no picture on the TV.
I haven’t found anything obvious to I changed the PI3USB with no effect.
After testing everything again a realized that the switch does not do any quick charge - so even when the switch is booted the switch is charging but only with 0.31A (both sides) - this is probably the problem with the dock.
As quick charging does not work on both sided I assume this is not a problem with the port (but not sure).
Any ideas / experiences what could cause a working switch from quick charge ?
