NS OLED blue screen of death
BSOD may be caused by APU,RAM,eMMC.
Installed rp2040.Now it requires sd card with hekate.Prepaired sd card 128gb fat32 with newest hekate.Does not boots to hekate,instead appears " Missing LP0 (sleep) lib"
“update bootloader folder”
trying to display hekate logo but with artefacts.
I assume if it was bad emmc,hekate should boot in that case.Remains APU and RAM.How to find out who is causing BSOD? Thanks in advance.
If reballing needed what max temperature can I apply on APU to avoid damage?
A bad emmc normaly leads to an error blinking rp2040 and not displaying anything. The “Missing LP0 (sleep) lib” error is pointing to an bad or incompatible (=> not for the correct firmware) install of Hekate.
If the BSOD is caused by hardware issue it is mostly a connection problem between SoC and RAM. Sometimes if you press on Soc and/or RAM you can localize the loose BGA connections.
latest hekate,rp2040 v2.73(latest)
Pressing on ram or apu doesn’t give any effect.will try instinct nx6 instead…
I red somewhere that during boot of hekate participate also ram modules and therefore i get this errors.
