Missing 3 capacitors in the HDMI IC area. PS4 model 1216a SAC-001
Anybody knows the values?
I have a first series PS4 from where I can hypothetically get the replacement capacitors.
Thanks
Thanks
I can not tell 100% sure, but I’m almost convinced they are 100nF 0402 capacitors
Thanks, will it work the same if I put some 1uf / 10uf caps?
It depends a lot on the function. If it is only a filtering capacitor for noise, maybe. If it is something else, probably not. Hard to say without having the schematic. But I think you can try safely. If that doesn’t work, at least I think you won’t break anything else.
