Ps4 pro moving with disk
hello tronics! without realizing I turned the ps from horizontal to vertical while it was on and with the disk inserted while the game was running. I do not think it was spinning at that moment, nothing was heard.
did this affect the device with anything?thx
It should be fine. I’ve accidentally moved it the same way with the disc spinning and while I’m sure it’s not a good idea it didn’t cause any problems. I did hear a rubbing noise from the disc when I moved it so it’s not good for it (when it’s spinning) but shouldn’t cause any permanent damage if you do it once on accident
The playstations enjoy the rough treatment mate they are built for it the Xbox is a pussy though you accidently bump it and it will run crying to it’s mummy sorry Tronicsfix it’s the only way I can think to phrase it
