PS5 BLOD and no measurable short circuits, total damage?
Hello everyone,
I could use your help. I have a PS5 Fat Digital (Board EDM 010) that beeps once, then shows a blue light for two seconds, and then turns off.
I can’t find any shorts or blown fuses anywhere.
I can rule out the power supply. Same behavior with a working PSU and a lab power supply.
UART only one Code:
UART Error Code 80810001. Power Sequence Error, General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
The startup sequence fails at a start at 1.7A, the next start at 30mA, the next start again at 1.7A, then again at 30mA, and so on…
In the sequences where it fails at 1.7A, you can see in the thermal image during startup that everything gets briefly warm (Southbridge, SSD controller, and various other chips), so it is actually trying to start.
What confuses me is that only the first 4 of the MOSFETs or DrMOS (the small black flat chips in a row next to the APU where there was putty that I removed) get briefly warm.
A small corner of the APU also gets briefly warm from the outside to the inside.
Does anyone have any idea, or do you think this is a lost cause?
startup sequence current should only around 300mA on edm010 board but you have 5x more current… There must have something glowing hot when drawing 1.7A
In my experience the startup sequence goes to around an amp once APU kicks in (at least from what I was able to see with a corner of my eye before pulling the plug, cause no heatsink :slight_smile: ).
However if only a corner of the APU gets warm like that it indeed looks like a dead APU. Sorry for your loss :confused:
Sorry I was really sick a long time. Since yesterday a startet working again at the console. It seems that it is dead due to a tiny crack at the apu corner. Didnt See it First but under the microscope in 4 k i saw it this afternoon.
