Hi, so I bought a ps5 off of eBay that said it had a problem with the display, and I thought it would be an easy HDMI port fix. But upon opening it up, there does not seem to be anything wrong with the HDMI port but I did notice that some diodes seem to have burst under the LAN port and I was wondering if this could be the issue causing the no display or if I should go ahead and replace the hdmi port anyways
lightning strike mostly based on the LAN port components burst. Does it even turn on normal at beginning(white light) and controller can get connected?
Yes it turns on normally and connects, even my tv recognizes that a ps5 is connected on the inputs menu, but no display at all
AS with ps4 console the HDMI ic or components in the HDMI circuite
