I’m currently troubleshooting a PS5 (EDM-010 board) with a 2-sec Blue Light of Death (BLOD), and I’m stuck. I could really use some guidance from the community.
Here is a summary of what I’ve tested and ruled out so far:
Symptoms: Powers on, emits a single beep, blue light stays on for about 2 seconds, then shuts down completely.
Standby Rails: All stable (5V, 3.3V, 2V, 1.15V around the Dialog PMIC RT5126) with no voltage drop before the crash.
Liquid Metal & Short Circuits: Thoroughly cleaned and checked; no liquid metal spill or short on the APU components. No shorts found on the Southbridge, Wi-Fi/BT module, or the newly replaced HDMI encoder chip.
Main 12V Rail: No massive short on the main input or the MOSFET input capacitors.
UART: Unfortunately, I get zero logs. I verified my CP2102 adapter via loopback test (it works fine), continuity on the TX trace is good, but it outputting anything.
Helped by this video : www[dot]youtube[dot]com/watch?v=KBA9Pf1kaak&t=697s. I monitored power-on voltages, and I noticed that one of the GDDR6 coil tries to ramp up (surging past 1.25V momentarily), but the second one stays dead, and the overall rail output never reaches its required 1V. The system cuts power right after this failure.
Has anyone encountered this specific behavior on an EDM-010 ?
Forgot to mention I have an EDM-020 board with disk. I checked all the fuses, they are all intact and ok. I also read the UART codes. I mean the same ones as described above. Hang a picture of it. I just can’t find the mistake. The thermal image camera also doesn’t really show anything as a short circuit. Power supply time with 300mA and then drops down to 6mA.
I checked the APU, it looks normal, no cracks or anything else. What I noticed is that there are no voltage concerns in the control system for GDDR6 switching, but there is also no short circuit.
