PS5 (EDM-020) BLOD / No Power after WiFi Chip Replacement
Hello everyone,
I want to share with you a strange experience I’m having on an EDM-020 which is confusing me given my little experience on the matter.
This PS5 comes with no signs of life, 270 mA current draw going to 0 and allowing me to press the button each 20-30 seconds, which lead the current to get back to 270 mA again.
I find a blown F7002 fuse, shorts on that area and UART giving an error code regarding the Wi-Fi chip, so I remove the chip and the shorts are gone, but the current draw is still the same.
Out of the two new chips I install, one works and the console, on PSU connection, spikes to 0.31 A then back to 0.00~0.01 A. 2 sec blue light on first click, beep on second click.
After a few tries it just dies, no initial spike and current draw 0.00~0.01A, no reaction on button press. No readings on UART.
To give it a try, I heated the the Southbridge and I get a 0.28 A steady current draw when hot, and either BLOD or no life described above when cooling down.
IPA evaporates on southbridge both on first power button press (blue light) and on second (beep), but I think this should be normal.
There is to note that the heat on that area reaches the wifi chip too and I still haven’t tried UART during BLOD sequence.
Any suggestions?
Thanks in advance.
Update:
After trying UART while on BLOD, this is the result.
00 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1520:E0)
Click for TSB Information
01 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1580:E6)
02 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1600:DF)
03 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0042 00000000 217C 0020 FFFF FFFF:29)
04 22/10/2026 19:28:19 80000009 Low Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
|-(OK 00000000 80000009 FFFFFFFF FFFF0042 00000000 217C 0020 FFFF FFFF:28)
05 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 16C0:F2)
06 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1620:E1)
07 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1680:E7)
08 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 172A:F3)
09 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
0A 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
0B 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1740:E4)
0C 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1720:E2)
0D 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
0E 22/10/2026 19:28:19 E3122454 High Not found in list. Report Findings.
Click Here To Report
|-(OK 00000000 E3122454 FFFFFFFF FFFF0000 00000000 2004 0000 0000 0000:72)
0F 22/10/2026 19:28:19 E2E01D06 Low Known Unknown E2E01D06 - Report Findings - Possible XDPE / VRM Related
|-(OK 00000000 E2E01D06 FFFFFFFF FFFF0000 00000000 2004 0000 0000 0000:8F)
10 22/10/2026 19:28:19 E1E0191D Low Known Unknown E1E0191D - XDPE Phase PWM Controller Error VRM 2 Phases
|-(OK 00000000 E1E0191D FFFFFFFF FFFF0000 00000000 2004 0000 0000 0000:92)
11 22/10/2026 19:28:19 E2200000 Low Known Unknown E2200000 - XDPE Phase PWM Controller Error VRM 6 Phases
|-(OK 00000000 E2200000 FFFFFFFF FFFF0000 00000000 2004 0000 0000 0000:61)
12 22/10/2026 19:28:19 E1200000 Low Known Unknown E1200000 - XDPE Phase PWM Controller Error VRM 2 Phases
|-(OK 00000000 E1200000 FFFFFFFF FFFF0000 00000000 2004 0000 0000 0000:60)
13 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
14 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
15 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
16 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
17 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
18 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 15C0:F1)
19 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
1A 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1560:E4)
1B 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
1C 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
1D 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
1E 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1540:E2)
1F 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
20 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
21 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1500:DE)
22 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1780:E8)
23 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1795:EE)
24 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 17A0:F1)
25 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 17C0:F3)
26 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
27 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1880:E9)
28 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 18A0:F2)
29 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
2A 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
2B 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 19E0:F7)
2C 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1980:EA)
2D 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1940:E6)
2E 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 18C0:F4)
2F 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
30 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1700:E0)
31 22/10/2026 19:28:19 E3122454 High Not found in list. Report Findings.
32 22/10/2026 19:28:19 E2E0191D Low Known Unknown E2E0191D - XDPE Phase PWM Controller Error VRM 6 Phases
|-(OK 00000000 E2E0191D FFFFFFFF FFFF0000 00000000 2004 0000 0000 0000:93)
33 22/10/2026 19:28:19 E1E0151D High Not found in list. Report Findings.
|-(OK 00000000 E1E0151D FFFFFFFF FFFF0000 00000000 2004 0000 0000 0000:8E)
34 22/10/2026 19:28:19 E2200000 Low Known Unknown E2200000 - XDPE Phase PWM Controller Error VRM 6 Phases
35 22/10/2026 19:28:19 E1200000 Low Known Unknown E1200000 - XDPE Phase PWM Controller Error VRM 2 Phases
36 22/10/2026 19:28:19 80000009 Low Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
|-(OK 00000000 80000009 FFFFFFFF FFFF0042 00000000 217C 0000 FFFF FFFF:26)
37 22/10/2026 19:28:19 E3122454 High Not found in list. Report Findings.
38 22/10/2026 19:28:19 E2E01D06 Low Known Unknown E2E01D06 - Report Findings - Possible XDPE / VRM Related
39 22/10/2026 19:28:19 E1E01D19 High Not found in list. Report Findings.
|-(OK 00000000 E1E01D19 FFFFFFFF FFFF0000 00000000 2004 0000 0000 0000:92)
3A 22/10/2026 19:28:19 E2200000 Low Known Unknown E2200000 - XDPE Phase PWM Controller Error VRM 6 Phases
3B 22/10/2026 19:28:19 E1200000 Low Known Unknown E1200000 - XDPE Phase PWM Controller Error VRM 2 Phases
3C 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
3D 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
3E 22/10/2026 19:28:19 80810001 Severe PowerSequence - Power Sequence Error - General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
|-(OK 00000000 80810001 FFFFFFFF FFFF0023 00000100 216D 0036 FFFF 1820:E3)
3F 22/10/2026 19:28:19 FFFFFFFF Low No Errors
|-(OK 00000000 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFF FFFF FFFF FFFF:5A)
