Ps5 No video, No Sound
Hello everyone, I have a PS5 (EDM-033 board) that has no video or sound. I’ve already replaced the encoder three times and taken measurements all over the board, but I still can’t find the problem.
The only thing I found missing is those voltages.
measure the voltage around the ic on the back of encoder, the 0.9v_hdmi is switch control by the 3 leg sot723 transistor
all good here
I already checked everywhere, the only thing I see is pin 19 with 0.0v and what was mentioned above
DIODE READING on pin19?
Diode reading on pin 19
0L
That seems to be an issue
yes, but I don’t see anything out of place, I tried the encoder on another board and it works, the encoder pads are healthy, the HDMI port has the pins well soldered, it has not been replaced, I am already out of ideas, the voltages look good except those mentioned at the beginning (the encoder goes up to 0.9v and goes down to 0.0v)
If i remember correctly, 0.9_hdmi will only be preseny when pin19 carry 5v(hdmi cable detected)
yes but it’s still at 0v
Check diode reading on HDMI encoder pin35
encoder pin 35: 0.6 diode mode
Ok then, you have a open/broken circuit between HDMI port pin19 to encoder. That’s why ps5 doesn’t detect HDMI cable and cut off 0.9v
could it be that the lightning burned the line internally?
Very possible the lightning burn the 22ohm resistor open, cause there are only few component(22ohm resistor and ziner didoe that’s all)) on pin19 circuit. Use continuity mode and check where your encoder pin35 to HDMI pory pin19 stopped.
FYI, such lightning strike background history should have mentioned mentioned at the beginning when post
I tried my best to make it easy for you to understand
from pin 19 to smd everything is fine, the other part is the problem
check that red circled 22 ohm resistor resistance reading across
I already replaced it with another one but just in case:
99 Kohms
22 ohm replaced with 99k ohm? why
it is the same smd of a donor board, it still gives the same value
