Current Boot Behavior: The blue light turns on for approximately 2 seconds before experiencing a protective shutdown. Previously, it once exhibited a database rebuild/factory reset error message before failing completely.
Current Characteristics:
Initial standby current sits around 200mA.
Current climbs to 220mA before instantly dropping to 2mA due to hardware-level overcurrent protection (OCP/SCP), interrupting the power sequence (a normal console typically reaches about 310mA).
[Key Diagnostic Data]
Secondary Low-Voltage Rails (Captured instantly upon press power button):
Near SSD chip: 3.3V measured.
Near RAM: 1.6V measured.
Near APU: 3.3V and 0.9V measured.
(Indicates secondary buck conversion circuits are functioning and the power sequence has reached the main power-on stage).
Thermal Imaging Observation: Among the 7 DrMOS power chips around the APU, the up first 3 lit up with heat, while the remaining 4 showed no response.
[UART code] 80800024 (Fatal Shutdown by OS request) right before the 2-second shutdown.
Any advise and troubleshooting suggestions would be much appreciated.
Can you try measuring more voltages and resistances around the board? I think this could be caused by a rail that’s enabled down the line, after the general APU power on.
Also, please take it with a grain of salt as I only have experience with EDM-010, but these two chips seems to be heating up quite a lot for what they are. On my board the only part that gets significantly hotter is the SB, SSD controller and APU/ram.
Especially this tiny little blimp on the right upper corner seems suspicious
I believe from the thermal image its the R3347 5 leg ic heats up, and it is likely for the XDPE phase controller voltage regulator. Replace them accordingly and see if making any change.
Before I attempt to do anything further it goes to safe mode today with cold boot surprisingly.
Cold Boot & Safe Mode Stability:
After being powered off and cooled down for 24+ hours, the console successfully performs a cold boot into Safe Mode and remains stable indefinitely without auto-shutting down. It only allows me to reinstall the system while other options like restart, restore ssd or rebuild database are not able to selected.
Even in Safe Mode with a verified good USB drive (rear port, no M.2 SSD installed), system software reinstallation consistently fails with error SU-101265-5 (“Update file corrupted”).
