PS5 Slim EDM-041 - Infinite BLOD - UART Errors C0020303 / 80C00140
Hi everyone,
I’m looking for some guidance : PS5 Slim with EDM-041 board.
Symptoms
  • Infinite BLOD / no safe mode
  • No HDMI output
  • Console has never been opened or repaired
  • No visible liquid damage or previous work
UART Error History (Console Service Tool)
The most common errors are:
C0020303
APU Not Responding - Trying Init or Reboot - 3
(System won’t start - Blue Light Flashes)
80C00140
MainSOC_FORCEOFF(TitaniaGPIO)
APU Halt (No Response)
80000009
Hardware - AC In Detect - Unexpected Power Loss or Shutdown Failure
The error log contains many occurrences of C0020303 spread over a long period of time.
Measurements
  • Main APU power rails are present during boot.
  • Measured approximately 0.9V on the CPU/SOC coils during startup.
  • No obvious shorts found.
  • Standby top current consumption is around 227mA after 2 seconds with 12V applied then go back to 0.002A after 2 others seconds
  • Console remains in BLOD rather than shutting down immediately.
Additional Information
Since the APU power rails are coming up correctly, I’m unsure whether this points more toward:
  • GDDR6 initialization/training failure
  • Missing clock signal
  • BIOS / NOR issue
  • APU communication failure or APU defect
  • Something else on the initialization chain causing the APU timeout
Questions
  1. Has anyone seen an EDM-041 with repeated C0020303 errors while the APU rails are present and stable?
  2. Would you investigate GDDR6 before considering the BIOS?
  3. Are there any known EDM-041 failure points that can trigger C0020303 as a secondary error?
  4. What would be your next diagnostic step: thermal camera, clock measurements, SPI/NOR activity, or something else?
Thanks!
