This is my first time cleaning my PlayStation5 so I am inexperienced. I replaced the liquid metal as well as cleaned the inside of my console and everything works fine except for the white light when the console is turned on stopped working as well as the beep when turning on the console and the power to the USB-C front ports stopped working. I did go through taking the console apart a few times since the console did not turn on initially, but I believe I just didn’t push in the motherboard into the power supply towards the end and got very frustrated so I definitely could’ve made some mistakes does anybody know what might be causing this issue? I could’ve definitely spilled some liquid metal on a chip or possibly scratched a chip because I used an automatic screwdriver but I tried to be as careful as I could any help is appreciated. Thank you so much.
Just adding more context, I did play overwatch two for about an hour and Black Ops two for about an hour and it ran fine. If I put the console into sleep mode, the yellow light does turn on.
Take picture of your front IO board cable gold pins, most case is either you damage the notch on the front edge of the ribbon so that it became hard to seat flat into the connector
I won’t have time to photo for a few days but I definitely remember seeing an edge of the ribbon cable looking a bit messed up. Is this an easy fix?
easy to replace, not easy to fix
Dang. Why do you say that?
Ohhh so can I just order a replacement ribbon cable and it should work if that’s my issue?
Do you know where I could order a replacement?
YES, the issue is very likely due to the mangled pins or the damaged notch causing the cable improper connection.
I believe many places sell this ribbon cable but just be careful buying the one for slim not the fat one. Slim has wider cable(more pins)
Thank you! I ordered a replacement I’ll keep you updated! I really appreciate the help
Just double checking, do I order the whole board assembly or just the ribbon cable and it can be replaced on its own?
Just ribbon cable, make sure is th notched one with same amount of pins
Thank you again! Ordered it!
Thank you!! replacing the ribbon cable worked
