Replacing the SMD components around the RST point on a V2 Mariko Board
Could anybody help me find which components around the RST point i have just accidentally removed on my Mariko V2 board (HAD-CPU-01)
I Know it was 2 small resistors below the RST pad though i dont know there values.
Above the RST pad was a larger black components (diode maybe?) whose value i also do not know.
Here is a photo of the stripped area, just besides the EMMC connector (also removed)
https: //ibb .co/f3TssfG
I have compared this area to my older Erista V1 board but there is a difference between the two boards in that the older erista does not have a larger black component in that same area.
https: //ibb .co/KzFxK1DL
The largest component is a protection diode, the resistor that goes right next to the diode is 35kh and the other is 4.5kh
