Short on BQ IC, not turning on, no draws
Hi guys, I got these shorts to ground:
As you can see i tried removing the BQ IC and the cap, but the shorts are still there.
Also i got 0L on CC1 on the usb port (pin 5) before removing the parts.
Any hints? Thanks
Bad m92t36?
I would remove m92t36 and check again.
This is the line to your bq short:
Yep, there was a bridge on the pin of the M92! Thanks!
Is there any “complete” map of the measurements of the pcb?
