I have a shortage near MAX77620A IC. I removed a capactor, but nothing was changed. Where can be a source of the shortage? Should I re-solder MAX IC again?
(In my case it is a Switch v1 board)
Check those burned capacitors mate they may be your short also check the main chip itself cause that could be the short too
Another capacitors are OK I think. Short is only on this line.
Does your “main chip” means Max IC or Soc?
your soldering work is extremely poor and it looks like several of those caps are bridged along with the giant lake of flux still there.
These caps are bridged anyways
