Switch Lite no charging only when console fully booted
Hey everyone,
I am trying to repair a switch lite here that had other previous damage. It seems as though the backlight was shorted which damaged a few things on the console. I replaced the daughterboard, main flex cable, main flex cable connector, and TPS61163. Now the console fully boots and everything else seems to be working just fine, except it will not charge the battery.
I tested the BQ24193 chip and even though it has 15V in and 4.2V out, I replaced it anyways with a known good working chip. This unsurprisingly did not fix the problem, but I am not sure where else to look. There are no shorts on any of the other components surrounding it.
Strangely enough, if I plug the charger in first and then connect the battery, it draws the typical ~0.5A at 15V and charges the battery. If I first plug the battery in and then plug in the charger, it boots the console but does not charge the battery at all, only drawing the usual power to run the switch. This might be typical behaviour, I am not sure, but it is odd to me.
I am not sure the fuel gauge IC is the problem here because if I power it with a bench supply at 4.2V the “battery” reads 100%, and even partially charging the battery on another console and hooking up this motherboard to it reads an expected value, such as 35% at 3.85V.
I am not really sure what to look at next. Any help on where to look next would be greatly appreciated!
