Hi gang
Switch lite driving me nuts…
Tried charged battery and it will not boot up fully… showed an error forgot error code…
so thought it might be m92 since not charging showing zero Amps on meter
charge port diode readings normal…
Changed m92
showed charging for a min at 15v .411 A
no image on screen ( screen is good )
then it just droped to 5v 0.05 ??
noticed board getting hot… was mosfet right above charge port ( back side )
removed mosfet still getting a short…
removed caps and m92 and BQ and still have short ?
Some caps ( directly behind /other side of cpu )
are also same 40ohm short
maybe bad cpu since it never booted and gave that error?
