Switch v1 does not boot (nintendo logo appears, then nothing)
I’m troubleshooting a Nintendo Switch V1 that boots to the Nintendo logo, then goes to a black screen.
What I’ve tried so far:
  • RCM works normally and Hekate 6.5.3 boots fine
  • Tried booting Stock/OFW and CFW — same result: Nintendo logo → black screen
  • Removed the microSD card — same behavior
  • Maintenance Mode does not boot
  • eMMC looks healthy in Hekate: Samsung, HS400, 100% life reported, partitions readable
  • Fuse count is 23
  • TegraExplorer detects firmware 22.1.0
  • Firmware dump completed successfully
  • Restored a full NAND backup from May 2026:
    • RAW GPP
    • BOOT0
    • BOOT1
  • Backup is also firmware 22.1.0
  • After full restore, exact same issue remains
One thing that looks suspicious: Hekate reports Battery Temp: -32.2°C, while battery voltage/capacity readings look normal.
After opening the console, I found that the white battery connector on the battery harness is deteriorated/crumbling, and one of the terminals had started coming out of the plastic housing. The gray sense/temperature wire may therefore not be making proper contact.
I’ve ordered a new HAC-003 battery and plan to check whether Hekate reports a normal battery temperature with the replacement.
Has anyone seen Nintendo logo → black screen while Hekate works normally caused by a bad battery, battery connector, temperature/sense line, or MAX17050 circuit?
sorry, used chatgpt to summarize my last month’s experiend, i also noticed that some of the screwd are missing (someone have already opened the switch probably..)
i got it 2nd hand (barter with an old cellphone) it worked for a few weeks and after the battery drained it never boot again.
any idea if the battey might actually be the issue here? ordered a new a one yesterday (its 10 usd) - did not want to disassembe the entire switch yet, not a big expert..
thanks !
