Trying to repair a non booting PS5
Hi guys,
I have this PS5 EDM-010 that i’m trying to repair. The console won’t boot with one beep/blue light then shut off.
After disassembling and inspecting the motherboard i saw a burned cap around the vcore rail
Replaced it with the same result.
Checked Standby voltage and fuse, everything is okay.
About poweron rail, 1vcore is missing, but i have 1.1, 0.8 1.35.
in diode mode mesurement values is 0 between gnd and the VCORE Rail coil.
i tried to injected 1V/2A on the rail but my bench power supply stuck at 1V/1.42A and only the apu is heating.
I also lifted all the coil from VCORE to isolate, i obtained .000 APU side and .142 Mofet side in diode mesurement.
Do you thing i can try something else or is my APU dead ?
Thanks in advance for your help. FYI i’m french so forgive me for the faults or if my message seems cold :slight_smile:
Hi. First of all, I’d recommend starting with the fundamentals. You can’t really expect to repair a board without first understanding the fuses, low-impedance areas, and the main symptoms and failure modes.
A console that beeps once and shows a blue light can be quite complicated to repair without proper diagnostics.
Could you post a picture of the area where you replaced the capacitor and explain more clearly what you mean by “burnt”?
Also, don’t inject voltage/current randomly. Injecting 1V at 1A into apu could potentially cause serious damage.
I’m sorry it seems like i’m not allowed to post picture. By burnt i meant one side of the cap was dark lile charchaol.
What can i do best to obtain a more precise diag ?
I usualy repair iPhones, sure i don’t know every things but i Hope i understand the basis :thinking:
Thanks a lot for your help
Upload you pictures at a image hoster (f. ex. imgur.com) and add a an underscore to the link, that you can post it. _imgur.com/123456
