tonike
December 22, 2023, 2:46pm
1
Hi guys,
Got one of those “half ampere of death switches” again and looking for any troubleshooting tips. Thanks!
Current draw 15V/0.45A
USB port is okay and diode values okay
Couldn’t find any shorts
Voltage lines seem to be fine, eg 1v8, 3v3, VBAT
CPU/GPU buck voltages are normal
eMMC seems to be fine (checked with another switch)
Installed modchip for hekate. Does not glitch, gives error code short,long,long
*== No eMMC CMD1 request (poor wiring, or dead CPU)
haven’t replaced M92 or fuel gauge yet
tonike
December 28, 2023, 4:28pm
2
Any troubleshooting tips or is it dead CPU?
PhynxVT
December 28, 2023, 11:36pm
3
0.45a draw with the board by it self with no battery?
Could also be a bad nand or a nand connection issue, you could try the nand module in another switch (unpatched, don’t attempt to boot into hos, just rcm then hekate
If you plug the switch into a pc with tegrarcmgui open does it pick it up in rcm mode?
tonike
January 2, 2024, 12:02pm
4
Thanks! I have checked the NAND with another switch. For bad NAND the modchip will give different error code.
tonike
January 4, 2024, 12:05pm
5
Surprise surprise. The culprit was faulty M92. I removed the M92 and could run Hekate. After installing the M92 the switch boots.
