Faulty Power IC (M92T36) PI3USB or Battery. M92 controls the charging If you are getting 15V 0.48A then its most likely the Battery or PI3USB as the M92T36 is communicating with the charger.
If you are able to power up and run the switch whilst the charger is plugged in then I would try the battery first. Unplug the battery and test the voltage with multi meter if its below 3.2V then battery is knackered or PI3USB is faulty,
