The 2 capacitors next to the two prongs on motherboard came off, now I’m just get the Blod. Will repairing the two capacitors fix the problem?
Duh, BLOD is a general fault. If you pulled the caps then its a no brainier. Solder them back on. If you pulled the pads, find the line they were connected to and run a jumper.
If that’s the only problem then yes if it’s not the only problem then no
