How do you reduce an HDMI port like this? Did they rip it out with pliers?
Suggestions?
Surely UV masking, then cleaning the solder and rebuilding the pad?
Or do I use an HDMI flex repair?
It’s an EDM 040, the capacitors are missing, everything is missing!
It doesn’t look like a diode to me, but I might be wrong.
Can you tell me the values of the missing capacitors/resistors? It’s an EDM 040
jkyoho
March 31, 2026, 4:03pm
3
The big diode should be “C1” or A6 label not a resistor over there
All components part number can be found in this thread
If you have a photo of an EDM 040, could you send me the HDMI part? This way I don’t make any mistakes in positioning
jkyoho
April 1, 2026, 12:30am
5
i thought the picture up there is clear enough
Thanks! If I understand correctly:
Side A:
1 x CDZT2RA5 5.6B Rohm Zener
1 x Diode C1 DZ2705600L
1 x 27K resistor
1 x 100pf capacitor
Side B:
1 x 100nf capacitor
Correct?
In the meantime, look what I found!
But how did it get there? It’s soldered!!
jkyoho
April 1, 2026, 2:29pm
7
correct, you prob found the 27k resistor ran into the playground
