About the Repair Tools category
This category is for all Repair Tool and Supply related discussions.
  1. Please be as specific as possible without giving unneeded detail
  2. Please update your question with the solution that fixed your problem if applicable. We’re here to help as many people as possible and the chances are good that if you are having a specific problem then other people are also likely having that problem.
  3. Be nice. Everyone here is volunteering their time to try to help you.
  4. There are no guarantees. We try our best to help but we may not be able to give you the answer you need and/or the answer may simply be wrong.
Looking to find parts to repair game contacts. I saw there are some that you can replace using a special soldering iron, though you can use a normal one. Saw the video that was with earth bound replacing a contact to make it work. If I could see where the replacement contacts are and soldering iron would help a lot thanks
