Asus X756UJ No Power
I have my dads laptop here, it’s SSD had started failing and the keyboard had a number of dead keys. It also had no working camera since we fitted a new motherboard a few years ago.
So I cloned the drive over to a new one, and took it fully apart to get at the keyboard.
This much I think went OK. I figured I was going to look into the camera after I have the first two sorted, but it turns out that the camera wasn’t working because of a bent pin which I didn’t check before re-assembling.
So, on trying to turn it on, there was no signs of life. Presumably the bent pin made contact with its neighbour. I bent it back out of the way, and tried again leaving the camera disconnected, but still no signs of life.
Does anyone know where I should start? Or have access to schematics etc?
The shorted connector does look like it was the (presumably) 5v line touching the neighbouring signal line, but it goes in to a via and I don’t know where it goes from there.
I have checked for shorts at the charger, 20v enters fine and gets past the first 2 mosfets and the current-sense resistor.
On battery, it similarly gets the 8v through the first inductor and pair of mosfets.
Checking all the inductors some are very low resistance to ground, but I do not know if this is low impedance. I have an old board that died in a similar way a few years back for spares, and its readings seem similar.
I tried looking for schematics for it, but they all seem to be behind paywalls that are more expensive that a replacement board.
I did manage to find this to reference, put I am not quite sure exactly what it is telling me… though it does seem to suggest some of the inductors have “low numbers”.
Eventually found the schematics, the USB goes direct to the APU, no usb-controller. Assuming that’s game over.
