BQ - Lifted Pad - Possible fix?
I have a faulted switch where I cannot find any shorts. The switch had some liquid damage mostly round the BQ chip. Once I changed the BQ I have seen that one pad is corroded from the water so I guess it is not longer working - probably this causes the problem with the switch.
Before I give up I’d try to bypass this PIN bit I cannot see any trace and do not know where a wire should connect.
Does anyone know if this would be possible ?
It connects to the same large pad as the one to the left of it.
