I have been trying to determine if I should replace the charge port or the charge chip. Or if I can do more tests to narrow it down.
The tester shows 0 amps.
No noticeable shorts on fuse or capacitors/coil.
Known good battery still shows 0amps during testing, but switch turns on normally and is playable.
I can’t see any bent or broken pins on the charge port, but I can see some corrosion that has been difficult to remove.
I have watched a lot of videos, and did the obvious tests, but I am curious if there are more things I can try to narrow it down to the charge chip.
