but I’ve noticed that this an inductor between M92T36 and usb port is open line and also part of an inductor next to the PI3USB (sry cannot post images)
are they the same, I think they should be in continuity
it would be much easier with a picture… if you can provide a picture i can compare with a working board. You will get access if you reply on posts and so on.
Its hard to help when the picture is taken from the side haha, but i think that the reading on the marked inductor below the pi3usb chip the reading is 0.746 on all 4 pins and the other 4 inductors are OL on all 4 pins.
Sry for pictures but indeed this is them.
You’ve measured between the ground and each pins of the inductors? When I say Open line it was between this 2 pins in resistor mode:
And what about the other one on the other side, same thing test conductivity between the 4 pins, I think it should be like 0ohms or near:
Ok for the PI3USB I’ve found on a post that it could be this filter:
EXC24CS350U
the link: frama.link/75bBJfPx
Watching the spec, it is an EMI filter with esd protection, seems to be a good ref.
for the other little one on USB @DSch I canot find the ref but someone will send a replacement part. Thx for the identification.
