Hello everyone ! Hope you’re doing well.
I bought a (gen 3 i think) cosmic red dualsense controller that would not turn on, on second hand market.
I took the controller appart, checked the battery : no voltage at bms terminals. So I went ahead and disassembled the battery further, in order to expose the cells terminals. From here, the battery read 2.7v. So I took my bench power supply to charge the battery enough so that the bms could reset, and charge the controller normally. When I plugged the controller, the orange LEDs would turn on and start breathing, just as if it charged. But the usb-c ammeter I plugged said it was drawing 0 amp.
So I bought a new battery, thinking the problem may have been the old one. Yet, same behaviour. Orange breath, no amp drawn. However this allowed me to turn on the computer, update its firmware, and check if it worked properly. Sticks work fine, triggers too. Buttons not recognized, but I’ll leave that for later.
I tried different cables, power sources… The behaviour is either no sign of life, or led + no amp draw.
So my questions are : is this a common fault, known from other users ? And could a faulty DA9087 power IC cause the issue, yet allowing the controller to turn on, and using it nearly normally ?
Thanks for your time and precious answers ! Have a pretty evening everyone ![]()
