Controller won't connect/charge after replacing joysticks. (JDM-055)
Hi all. A friend of mine gave me two PS4 controllers (JDM-055) to install Hall Effects in. I’ve done it before to multiple controllers. Never had an issue. I thought I had taken enough extra care to not interfere with any other components on the board when taking the old sticks out. However, after installing the sticks the controller won’t charge or stay on. Pressing the PS button makes it flash like it’s trying to connect and then it turns itself off after a second or so. PS4 won’t recognize it via USB and my PC won’t either unless it’s through Bluetooth. I can get it to enter pairing mode and it stays on until it connects to my PC but then it shuts off right away every time it is turned on. Hitting buttons as soon as it turns on while it’s connected via Bluetooth to my PC and using a gamepad testing site, for a split second I can see the buttons work. I’ve also tried a verified working lower half of a different controller (with the ribbon connector and the USB port) and it appears to be the board that has the issue. What could possibly cause this and does any one have an idea of how to possibly fix it?
Pictures of the board in it’s current state:
https://imgur.com/a/PYyxlCf
