hello, I got a dualsense bdm 030 with a torn USB socket, the solder pads from the left 4, 6, 8 and 9 were torn off. I regenerated 4, 6 and 8 but 9 probably has no signal because I can’t see the path anywhere. Generally, the controller turned on until I soldered a new USB socket (compatible with dualsense). Now after connecting the battery or USB cable it blinks orange twice and doesn’t turn on, I’ve already replaced the Dialog system but still the same. Can someone help?
Hi, the two orange flashes mean the battery isn’t connected. Plug it in normally, and it should start charging. If not, try another battery.
hello Halotestin92 !
did you manage to solve the problem? I have the same problem. I haven’t tried it with another battery, but I don’t measure any voltage on the motherboard battery connector.
