Dualsense bdm030 L2 reacts when right stick moving
Hello everyone, I received a controller from a friend after a failed analog replacement. The left analog worked fine, but the right one didn’t respond to R3. The problem was a cut trace, which I fixed. During testing, I noticed that when the motherboard is connected without a case, the left trigger is active, but when I turn the right analog, the L2 button changes values. The problem disappears when the motherboard is inserted into the case and in contact with the button ribbon, but as soon as the button ribbon is disconnected from the motherboard, the problem returns. I know a working motherboard doesn’t behave this way, and I’d like to fix it, but I need your help. For now, I’ve replaced the analog modules with new ones, and it’s still the same.
