I found that pins 17 and 18 of the DA9081 are outputting only 0.7–0.8V instead of the expected 3.3V.
I traced this power rail and found that it passes through two ferrite beads before reaching the Southbridge.
To rule out a faulty replacement Southbridge (all other measurements are perfect), can I lift the two ferrite beads to isolate the SB and check whether the DA9081 output returns to 3.3V?
Would this be a valid way to determine whether the Southbridge is pulling the voltage rail down?
Yes, I understand, but my intention was to electrically isolate the Southbridge from the DA9065 to determine whether the SB is pulling the 3.3V rail down to 0.7–0.8V.
If I lift the ferrite beads, wouldn’t that allow me to check whether the voltage returns to 3.3V on the DA9065 side?
