EDM 040
1 sec. BLOD
UART: 80801F12 => C810303 => 8081001
Missing 3V Standby on PIN 13 HDMI (not shorted)
Left side 4.65V, right side 5.13V
what do you think?
I have a second EDM 040 for testing and the same value is found on this one too.
Resistor left side 4,65V , PIN4 15JL 4,65V
how much resistance measure across the resistor? I measured 5.13v from 5v_standby on the right, and 5.0v on the left
99.1Kohms across the resistor
(the second board has the entire HDMI part destroyed, both the pads and capacitors/diodes are missing, so the measurement is distorted, I will not take it into consideration)
HDMI pin 13 (CEC) should have a voltage (measured aprox. 4.5V) reading in standby.
I would check pin 39 at the HDMI chip for correct readings (2.5 MOhm/700 mV)
