Error code on Nintendo switch, USB connector with bent pins, M92 chip shorted
Those grey squares are inductors and usually are low impedance lines so they will cause your multimeter to beep, you want to double check shorts by checking resistance to ground, look over your m92t36 install, check each pin
Continuity on M92, everywhere else there is nothing
Can you tellme where I can buy this usb pinout board?
anywhere, make sure you get the 24pin ones.
