Hi all,
I used a SX Core to hack an Oled Switch. When I turned the power on, the SX Core flashed from blue to green, and the Hekate menu showed. I chose launch, this error occured, on both original and custom firmware and couldn’t be booted:
Failed to init eMMC
Failed to launch HOS!
Hope that someone can help me solve this. Thank you!
Would imagine your line to the EMMC is touching something else which it shouldn’t and/or if you lifted the EMMC IC the reball/install isn’t good, hopefully you have a full backup of the eMMC incase the EMMC IC is damaged
I use pcb adapter, not reball emmc ic
I had the same issue before. It is the dat0 adapter. I would redo it and keep the enamel wire from bending too much. and make sure the solder joints are tight.
