Fail to init Emmc
Greetings to all
buy a used nintendo swith with the problem that does not turn on
I measured the capacitors and none are in short
load at 5 volts and 0.40 amps
I realized that it is only in rcm mode
in Hekate it shows “failt to init eemc”
any idea how to fix?
I use google translator, sorry
Hi,
looks to me like the emmc is faulty and you can’t do much. Are you able to make a Nand backup or get the prod keys?
Cheers
I would open it up and check for any damage or corrosion on the emmc or the connector to start with.
upgrade
buy another broken nintendo switch with missing tegra processor capacitors
I changed the emmc of the first switch and recognized it with the hekate
I rebuilt the nand with files that I found on the internet and it already works, only now my console does not have a serial number and I cannot access the internet
Cheers
