Playstation 4 Fat, with update error loop (SU-30645-8). This error occurs when one of the Samsung K4G41325FC-HC03 Ram Memory is destroyed. Here i will show you how to fix this error. You can start to change a piece of memory and then test if it updates or change all the memorys ram on the side of the motherboard and then test. In my case i changed six pieces and the console started to update and i solved the error. Thanks and sorry for my English.
so you did the process of replacing the ram chip 6 times until it worked?
I replaced 6 pieces ram memory in a row until I hit the defective one.
